1 - 6 of 6 Posts
ok so I have been having a problem with my oil pressure and I start looking at the oil pressure sensor and there is oil all around it and all over the distributor I saw some antifreeze and it looks like it is in the top of a hole
628401
i have a v6 3.9 I also have a few more questions about the truck I will post pictures and questions later
don't believe the dash gauge. rent the testing tool from the parts store. take out the stock sending unit and plug in the tester.
If it isn't a sensor failure, then your oil pump is failing, you have excessive bearing clearances, Or you have a clogged oil pump screen. Has the oil always been changed on time? What is the mileage? Try switching to a heavier weight oil - if the light stays off, then you have a genuine oil pressure problem. This will buy you enough time to search for another vehicle and/or save up for an engine rebuild/replacement.
Showbox jiofi.local.html tplinklogin
1 - 6 of 6 Posts
