Can someone please post this at the top of the interior/exterior section, as a sticky, with the other “how-to” threads; I’m not sure how to do that…Thanks! Well guys, here it is; this is my thesis on the suede headliner/sun visors install. I will do my best to include each step of the process without making the process too lengthy. I found, through experimentation, that you don’t have to remove your front seats to remove the headliner. You can do this one of two ways: unbolt the front seats, and pushed them into the back seat, or recline the front seats all the way back; I have successfully removed the headliner without removing the seats. The following instructions are based on a 2005 Ram 1500 Quad Cab, and these instructions are in no way an exhaustive representation of the proper techniques for the application of a suede headliner/sun visors; this was simply the way that I went about the process. Good luck, and remember, have fun!
Materials: 4-yards of black woven suede (Hobby Lobby $55) and 1 bottle of 3M spray adhesive (Home Depot $10). I bought more suede than I needed so that I could wrap additional items too. When I began looking for suede, I found about 10 different “styles” of suede (woven, butter nut, synthetic, etc…); so, shop around for the suede that you like. As far as the spray adhesive goes; I recommend buying the stickiest one you can find. The can lists what the adhesive will bond. I used the “3M Hi-Strength 90”, but I assume that anything above that strength will work as well, or better yet, try some upholstery adhesive.
Step 1: Unbolt front seats, from the floor, by removing the four bolts located at each corner of the driver and passenger side seats (8 Bolts total), or recline them all of the way back (like I did); if you recline them all the way back, you do not need to do step 2.
Step 2: Slide the front seats into the back seat, or remove them completely.
Step 3: Remove the plastic covers on the A-pillar with a flat-head screwdriver. Next, remove the two 10mm bolts from the access holes (Figure 1). Finally, gently pull the pillar by the handle to release it from its location (be gentle; the pieces are plastic, and they will break). Repeat this process for the other side of the vehicle.
Step 4: Remove the sun visor by removing the three torx bolts (T-20) from the mounting base (Figure 2). Repeat this process for the other side of the vehicle.
Step 5: Gently grasp the sun visor plastic hanger, and give it a firm pull; the hanger should slide outward and lock (Figure 3). Next, grab the base of the hanger, and give it a firm tug; it should pull completely out. Repeat this process for the other side of the vehicle.
Step 6: Remove the overhead console by gently prying the lens covers from the map lights. Next, remove the two torx bolts (T-20) from the console (Figure 4). Finally, gently pull the console downward to release it from the mounting clips. Remove the two wire connectors from the map lights and the overhead console computer (Figure 5).
Continued Below...
Continued Below...
