Backwoods Hillbilly
The following few posts are my how-to on how to fix your Durango's power window problems for cheap. Pick up a new assembly from the dealer for a few hundred dollars or more, pick up a used one on ebay for $100 or do the deed yourself for a few bucks!
This won't fix all problems that can be encounted with the power window assembly, but my guess is that 95% of the problems that people are having with the windows come from a problem that is just as simple to fix as putting on a new distributor cap and rotor on your engine. As a matter of fact, it is the same concept.
First, a pic of what is causing the problem to begin with. Pictures below of the right hand and left hand side brushes. Notice how worn that they are. This is causing them not to be able to contact the magnet with the amount of force that they should, thus why the "bang on it with a hammer or hand" works for a while because it gives you a bit more grab for a bit, but isn't a long term solution.
Backwoods Hillbilly
Discussion Starter #2
First, you need to remove the window regulator and assembly from your door. Just remove the door skin and there will be holes available for you to access the area. Consult a FSM or a Haynes repair manual on how to do this as that information is readily available. Your removed assembly will look like what is in picture 1.
In Pic 2, you see what we're going to be working on. That is the window motor itself.
Pic 3 shows two phillips head screws holding on the housing. You will need to remove these (there are nuts holding them on the back side, so make sure you are aware that they are there). The housing is magnetized, so just give it a tug to get it to come off.
Pic 4 shows the actual magnet. If you've ever rebuilt an alternator, you see where we're going with this. Same deal. :)
Backwoods Hillbilly
The next step is to remove the magnet so that you are able to access the brushes. You simply need to turn the magnet and pull at the same time. It will come out. These Pic 5 and Pic 6 show what it looks like after removed.
Next, you need to remove the brushes themselves. You'll see brass connectors holding them into place. Take a flat head screw driver and gently lift the connector up. After that is removed, remove the small spring holding the brush into place with the flathead as well (Pic 7). Repeat this step for both sides. Don't worry about which side is which in regards to the brushes because they are the exact same.
Next, get everything cleaned up. Gently tap your parts on the table a bit and watch all the black grit come out. Clean up all contact points. Then reinstall the new brushes (which you can pick up from a hardware or auto parts store like NAPA). I don't know the exact size to ask for, so just take the old ones along with you and match them up for size. The square part should be the same size, but obviously you will want them a bit longer than what you took off so that the contacts are restored. Don't forget to clean out the housing as well (Pic 8).
Assemble everything back, try out the windows and rejoice in the fact that you have just repaired your window for a few bucks instead of a few hundred. :rck:
