I'm glad that the this fix was easy to do and didn't require the dealer to do it.Psyclone said:My problems was stalling when warming up. It would start fine. Run fine but when I was coming up to a stop sign it would just die. It would start up again but die again. This fixed it up just fine.
You have a different set up. You have and Idle Speed Control Actuator instead of the IAC.Dennis D said:Stev, Do all TBI's have a IAC valve??? I have a 1990 Power Ram, 318, (5.2?) with a Holley TBI.
Sharon,lanesharon said:Tried the IAC clean, and it didn't get rid of the p0505 code. Then did a complete tune-up (spark plugs, wires, rotor, cap), still got the code. Then, I finally bit the bullet and installed a new IAC. Still getting the code. The only thing that has changed is that the light only comes on sometimes now. I can't figure out what is causing it, because it happens when it is code or warm. When it does come on, I notice a marked sluggishness in the engine and rough idling. Does anyone have suggestions?
Take Care, Sharon
