1 - 20 of 50 Posts
Creature Of The Wheel
How much engine & rear wheel hp do u think i'll have with these mods? How much hp/tq do you think these mods added over stock?
SCT 93 octane custom tune
Flowtech Shorty headers into a hi flow y-pipe & cat into a cutout (maybe like 10hp for full exhuast?)
52mm Bored TB
K&N 14x5 round air filter
ASP Crank Pulley (ive heard maybe 5hp max?)
Then how much more hp/tq do u think if i get some HS 1.7 Roller Rockers? (i've heard like 5-10hp maybe?)
I want to dyno it bad, but dunno if i should even think about it on a truck with 128k miles...lol
Ram Racer
220rwhp give or take Id guess and maybe 290 crank.
128k, strap her on the rollers :rck:
290 is a lot more than i thought...but i have no clue on any engine stuff, so u can throw my guess out the window...lol that including the roller rockers if i get them? I'd be very happy if its 290 or anywhere close to that.
So i should be ok putting it on the dyno?
of course if i ever do it'll be after i fig out this starting issue & maybe take it for some tests with the dealer.
You probably see more gains by just changing to Hughes iron ram heads there $300 and you can swap you ext and intake valves over to them.
REDNECK SPACESTATION
mine had 130k on it when I made my pullls before and after the intake swap.
You'll be fine, just try not to bounce it off the rev limiter.
Black Sunshine!
128K really isnt that bad go dyno your rig
the rockers are more than 10 hp, it def a mod to do if you want power down low to get up the rpms faster
Senór Member
52mm Bored TB
10000000 hp at the crank and 10000 RWHP...:tup:
but 1.7 are rated 15-30 you would prob see more towrd the 30 because you have other mods benifiting, as if you were to have a stock motor you would prob see more like the 15 hp . but make a new tune for the rockers if you get them.
Ram Racer
52mm Bored TB
If your gonna put headers on i would recommend putting long tube headers on, shorties dont really do anything. To get the full gain from a set of headers you really need a long tube style.
what kind of hp sauces will i be looking at with my following mods?:
Hughes Iron Heads 2.02's
Ebay shorty headers
Comp Cam 262
Open element air filter
Super 44 w/ 3" pipes
Msd Coil & 6-AL Box
SCT Tuned
Ebay shorty headers
Comp Cam 262
Msd Coil & 6-AL Box
SCT Tuned
change the shorties to long tubes. Probably be around 400 horse or a little less.
with my 318????? hollyyy BLEEEEEPPPP
1 - 20 of 50 Posts
