what 6" lift did you use?
Zone 6".
My thoughts.........
I've been reading up and researching the Zone products. I'm buying a 6" off a local guy this weekend. New & in the box for much less than buying from retail. He traded the truck for a 2500 before installing it. Score fer me!
Anyways.......The Zone lift(and it's literally different colored
twin, the BDS 6") is designed to just lower everything in the front a sufficient distance to create 6" of height. The spacers and parts aren't
truely 6" b/c of angles and such. Once you have dropped all the components up front & you install the blocks in the rear.......all angles, geometry and otherwise remain very, very close to stock. B/C of that, you still get some of the nose down rake. I have decided there are only 2 options on how to deal with this safely. You can A) Install the Rancho QuickLift or better - the Bilstein levaling struts at their 1"+/- setting -or- B) Go with shorter block in the back. I'm going to wait to see how much rake is there. I tow with mine, and I may choose to leave it. If the rake bothers me enough to spend $5-600, I will buy a set of leaves with 5 1/2 inches of lift in them. I have found 3 retailers that sell them, but I beleive they are all made buy the same spring house. I really, really would prefer my rear lift to come from springs, b/c of towing.
Hope it helps, or give you something to think about.
ps. if anyone reads this & has an idea on hwere to get 5-6 lift leaves for a 06 without spending so much.....I'm listening.
pss.......when I say twin, I mean twin. The Zone is owned by BDS.....the BDS Stage 1 kit is blue......Zone's is black. If you go to each websiste, open the image of the kits laid out, one in each window, and look at them side-by-side....I have read that the shocks are diff, but.....as far as I can tell....IMOHO....well.......apparently the blue powdercoat is what makes the BDS so more
