djturnz said:
Why would you rather use your wheel wells than your stake pockets? Doesn;t that bend the sheet metal? I also use ratch straps as well.
I also have a hard plastic bed liner so I don't have any way to use the inside bottom corners. Are there hooks down there?
Yes. I have a hard plastic liner that came with the truck when I bought it, but it has 4 rubber plugs that are about 4" across that pop out of the front corners on the floor, and the back sides as well. There are hooks on the floor in the front on either side, and there are two on the sides of the bed near the back kind of near the tail lights that would be hidden by the bedliner unless it was specially made to include cut-outs for these hidden hooks.
I use them all the time with ratchet tie downs to secure loads, but I also use them in conjunction with the 4-point tie down hooks on my rails which you wouldn't have it you got a tonneau cover.
