to get it out, you will need to tilt the entire dash forward to get 3 or 4 rear facing screws right next to the 7mm bolts you pulled out by the window. Take off your kick-panels and losen to 2 large nuts in each corner. Then pull the center cover off (right under the cupholder, against the floor). Then remove both a-pillars. Once thats done, you should be able to wiggle the dash a little. Remove the steering column bolts and drop your steering wheel as far as you can. Now comes the tricky part. If you have small hands like I do, this will be easier, but its still going to cut you up pretty good... get the smallest stubby phillips screwdriver you can find and reach in next to each of the 7mm bolts and remove the screws. Then you should be able to see the screws for each vent.
I believe that was all of the bolts I remember.
HTH
Kenny
