1 - 17 of 17 Posts
Im getting a vararam and need to relocate the old school overflow radiator bottle that sits on top of the fan shroud. I couldnt find the answers i needed when i searched so.....what size bottle do i need to buy? im just goin to get a cheap one from auto zone and what kind/size of hose do i need to buy for this? Is there a certain type that can withstand the temps, and what size/thickness/length do i need? Is it o.k. that the bottle will be lower than the OEM bottle was on the shroud? Alot of simple questions, i just want to do this as easy as it should be.
Don't know if this will give you any ideas or not, but this is how I did it with a normal CIA.
Discussion Starter #3 (Edited)
thats nice looking. im still confused by this even though its so simple. Do you know what size bottle i need for the coolant? Summit racing has ones that are 1qt and 1.5qts and so on. Also do i need a catch can or overflow bottle?
They are probably interchangeable, neither is a pressure vessel. I would think catch can for more like a transmission breather, vent tube, but if it fits it works. The ones in the picture came from Pep Boys, like $10.00. 1Qt. seems a little light.
The 2003 has a pressurized coolant bottle as the radiator does not have its own cap.
Motörhead For Life!
But you can replace the radiator with one with a cap if needed.
I forgot that, now I don't know what to say, unless someone makes one to accept a radiator cap.
Like Voodoo said, you can swap out the 2003 radiator for a 2004 that does have a cap but that would probably cost more money.
If you have stock water bottle just rotate it 90 degrees and make two "L" brackets to mount it. I kept the same hose that comes out bottom of the bottle and got longer hose from bottle top to radiator.
Tex
i have a shroudless install on my truck and the overflow bottle is just mounted to the radiator using the materials supplied in the black magic 180 kit. a local member did the install and did a freaking awesome job
Redtruck-VA
Well done guys,
Discussion Starter #13
thats just what im looking for, saved me a lot of thinking. hey do you know what kind/size of longer hose you got for the top of the radiator?
Get same size and kind as whats already there, just longer. I think its 3/8 or 1/2"
at any auto store.
Try harder
Kris is you need any help with the install and I'm off work, just let me know and I'll come by.
Discussion Starter #16
cool man thanks, it should be easy but you never know, ill let you know if i cant figure it out.
It's been a couple year's now,but if i remember correctly the vararam kit came with a brkt. and hose to relocate the bottle on the 03's.You should'nt need anything else.
1 - 17 of 17 Posts
