1 - 2 of 2 Posts
It's gasket and seal time on my 5.9 with 190k miles. this is the frist "major" engine work i have had to do since i bought the D 6 years ago :rck:
i got a week off of work soon and looking to fix a front seal leak that is leaving spots on my driveway. Going to do the rear main as well. AND also might as well replace/rebuild the oil pump since i have to take that off anyways.
while the oil presure is still good, i am thinking with the increased space between the bearings from 190k of driving, it would be best to install a high volume oil pump for $25 more than a regular one.
Has anybody had problems or heard of problems with oil starvation with the stock pans from high volume oil pumps?
CC:
Not sure why removing the oil pan would require you to bother the oil pump. Unless you are rebuilding the engine and increasing performance a whole lot over stock, I would stay with a stock pump.
High volume is not better than OEM for a stock motor.
Don
1 - 2 of 2 Posts
