hey guys i just got some magnaflow hiflow cat's in today and i was looking at the o2 senser wires and on the passenger side thay wont be long enuf to run behind the new cat's is it ok to cut them wires and make them longer or will it mess shit up:help:
Valdez Racing Team
it's ok to cut and splice in wire...i did that when I did my exhaust..
You can probably just pull the O2 harness out of the clips that hold it to the trans to get a little more length. I realized that after I lengthened mine. If you do make them longer I would solder the joints, because the voltage on O2 sensors is very low and connection that is just slightly loose will cause false readings. Or, you can buy O2 extensions from Moesperformance I think.
Toothy Critters Rock!
Yep I extended one side of mine on the 06. (soldered)
At least back then the extension wire sets only fit the rear o2 harness not the fronts.
