1 - 20 of 20 Posts
i have an 06 ram 1500 with halo projector headlights. i just bought hid kits for them. all they did was flash a few times then go out. i researched and found i needed some resistors so i ordered them and installed them but there was no change. if anyone knows what i need to do i would love to know. its starting to get pretty annoying. thanks
you need to wire in a resister between the battery and relay... and one after the relay on the other side before the ballast... I have 55 watt kit I just did yanked my 35 watt kit... I also have 2 resisters after each ballast also so a total of 4 resisters... no lamp out light and no flickering... If you do fog lights there is no need for any resisters... hope this helps
you need a resistor in the empty plug on the RH side I too have an 06 that did this.
I'm not sure if the 02-05 are different then 06-08??? also I'm only running HID low beam not a Bi-xenon
Discussion Starter #5
what do you mean a resistor in the empty plug?
are you running a single low or Bi-xenon??? try wiring a resister in before the relay and one on the passenger side before the ballast... all you are doing is fooling your onboard computer that that there is a light working there since HID's draw less power
You need to use an hid harness bc at start up they draw too much power and the computer turns them off and on . I got an ebay harness that had a relay and a plug in resistor for the right side
Grabbin life by the horns
Anybody got a diagram showing exactly where I need to put the resistors? Also I would be using h1's for the projectors not bixenon. Did you still use a wiring harness/relay with your projector setup?
AROD'S TRUCK
With most HID kits they only use one Headlamp plug leaving one unused. I have Hi/low 5k 35 watt kit. I wired in a total of 4 resistors 2 per side. 1 for high and 1 for lows. Once I did this all problems went away.
Check out my thread: http://www.dodgetalk.com/forums/showthread.php?t=292977&page=3
I also used some knowlege given to me by Weedahoe
Hope this helps
I have a diagram it's in my buddy's email... I'll have him send it to me and post it tomorrow... It much easier for me to show that then explain it!!!
Tricked out Ram
Here are some pics of mine
Pass Side
Drivers Side
I too have projector lights with h1's, like I said get the single hid harness on ebay just make shure it has the resistors built in. For my high beams I made my own harness so I can flash my lights without turning off the hid low beams .
Discussion Starter #13
so basically if i just want my brights to be regular i need to get 2 of the single ebay harnesses and hook one to dims and one to brights?
For my high beams I made my own harness with a 30 amp relay and a new switch on the dash, so now if I want to I can have all my lights on at the same time (low's, highs, fogs)it's like looking into the sun .
Any info on which sellers on Ebay sell the kits with resistors built in?
I got mine from ebay seller phillipsxenon
Tricked out Ram
my twiggy harness came wired up backwards the low and high beam were .
CODE RED
so just a resistor on both sides would ace the lamp out and the flicker?
AROD'S TRUCK
I have 4 resistors, 2 on each side works with no problems.
1 - 20 of 20 Posts
