Yes, Dodgevanman it will stay running if i hold it but not at lower idle. i have to hold it about 1/4 throttle or it will try to die out.
B-300, yes both are working and have voltage. As for the filter, it was just replaced but i suppose the is cheap enough to rule out. Yes the actuator works, when you turn the key on you can see and hear it moving. then when it starts it seems as if it cant make up its mind, in or out.
today I went to the junkyard to find another for other parts and it just ran like crap. cutting out when you let off and step back on it. almost dies from a start. I unplugged the ISC motor and drove it for a few like that but it didnt seem to help. it's really intermitant. would the EGR be a cause. someone did gut the cat, but the EGR line is still there. Also what are a few ways to test if EGR, ISC, MAP, coolent temp sensor, throttle body temp sensor...? Thanks for all the feedback so far. Any help is good help.
