I have a 98 Durango SLT. I want to put a 2000 or 2001 dash in so I can have disk climate control. I know I need another HVAC door. Can I use the dash harness on the 00 or 01 dash? From what I understand they run on the same system until 02 so I don't see a problem with it. When I did a dash swap on my 02 RAM to 06 dash they had different BUS systems so I had to use the 02 harness. Also I want to add the rear air control. Is a 98 capable of that? What I mean is if I get all the parts and wiring is it plug and play? So it boils down to can I use the 00 or 02 dash harness and can I put the rear air control in my 98? Thanks MoparFanatic
