I got my codes pulled a few weeks ago, I misplaced the codes but the dealer still has record of them , i should call them but basically I got a code that said main realay open. Where is the main relay? I looked under the hood fuse box and nothing in there labeled 'main relay'. I also looked at the fuse panel in the cab and same deal there.
I also got a brake switch circuit in the abs module code. Anyone know what that is? Is the the switch right above the brake pedal? My brake lights work fine.
The reason I checked the codes is because my abs and brake dash lights come on every once and a while. The cruise also stopped working around this time. I did some searching and I am about to buy a new 'ouput shaft speed sensor' to try to fix this problem. If that don't work I may try the real wheel speed sensor. After seeing these codes I guess I might want to try buying a new brake switch above the pedal even though my brake lights work.
I drive a 1998 5.9 d-go
Thanks,
Ryan
Thanks,
Ryan
