21 - 26 of 26 Posts
roughly 10-15 after starting that it dies
I had a similar issue with a crank sensor. It was replaced and worked well for about 6 months. Then every once in a while it(motor) would cut out just for a split second. It progressively got worse until it would cut out about 6-10 times per half hour of running.
At it's worse it wouldn't cut out until 10 minuets after starting. Just enough time to heat things up. I replaced it with a delphi part from rockauto and truck is running fine now. Where did you get the sensor? Pep Boys? Crank sensors are hall effect sensors usually 3 wires positive voltage negative and then the signal. If you have a wiring diagram of your truck and can find the signal wire from the sensor going back to the pcm you MAY be able to see if it's getting a signal. Do you have you old sensor? Since you are still getting the code 11 it has to be in the crank or cam sensors or the wiring to or from them.
Discussion Starter #22
I purchased it from autozone, I honestly believe I havent started having all these problems till i had to replace the crank sensor and no the old one was cracked so i tossed it. My next step was buy a good sensor from the dealer or rock auto.
could it be the cat plugging up after running for a bit
I've had similar symtoms with my truck. The first time, it was the O2 sensor with a frayed wire. I changed that out with when I did the intake gasket. Solved the problem for a while. Recently experienced the same thing again, and noticed the temp gauge was not registering above 135. When I changed out the temp gauge, the idle fluctuation went away, and so did the stalling. Since you had a temp code, it is worth a try.
Glad you are up and running, and thanks for the update, thins thread could easily help others with similar baffling problems.
21 - 26 of 26 Posts
