Hi everyone my names Dustin, bought a 2006 dodge magnum 2.7 . From a guy that drove it to my house two days before. Running fine . Anyway car won’t start now. Unless I flutter gas pedal like crazy , the second I let off it dies out. If I unhook the pcv hose from the intake , or remove map sensor from intake port , allowing the engine to suck in air . It idles but of course rpm fluctuate when pressing gas due to the vacuum leak. So I replaced intake tuning valve, new spark plugs new fuel pump, new pcv valve , the throttle body ,and intake manifold gaskets and valve cover gaskets and checked baffle where pcv valve going into the intake , confirmed compression and timing ,no check engine lights unless I cause it myself ,, what could possibly be wrong this is crazy , like I said it will only idle on its own when map sensor taken out of intake manifold or the pcv hose undone from the intake manifold:
