Today I noticed my tranny is leaking really bad. I was wondering if this is going to be a major repair and costly? I got a picture. Thanks for any help!
No way to tell for sure till you get it apart. They are charging $500 just to take the trans out?Ah your starting to scare me tactransman. The shop 2 blocks away said it will cost $500 to remove the trans and then parts. He seems to think it might be the bushing, pump seal or converter. I only got a $1000, I hope im lucky. Is there anyway to get a better idea with the trans still on? It's not leaking when shut off, it pours out when running.
Thanks for all the help and info guys!
Your is probably a hardened pump "O" ring.mine does the same... except its a small drip when driving or when parked....
