Dodge,Intrepid/2000
The light bulb on the dash that backlights the left side of the instrument cluster (lights up the gas gauge) is out. I was told I needed to remove the plastic bezel around the cluster, and gain access to it that way.
Has anyone faced this before?
I found 2 screws after removing the fusebox cover and was able to loose one side, but not much flexibility after that. I'm trying to avoid dismantling too much, and any input would be very much appreciated.
Looking forward to hearing from someone.
Thank you.
Dave S.
Thank you.
Dave S.
