ATLHEMI said:
My next project will be to replace shocks and level my truck. Whats the consensus on the best aftermarket shocks for the RAM? I want to level my rear-end with my front-end and have no experience at all. Recommendations?
I just added the spring clamps too, removing the center spring at the same time. While it gave me the
exact look I wanted, adding the clamps seriously reduced spring travel, and the rear bottoms out way too quickly now on even the smallest bumps. Not a good ride, and this can't be good for the truck over the long haul. My next move is to crank the tbars to raise the front an inch, and slide the clamps to raise the rear an iinch and a half. The front to rear half inch height diff will be barely noticeable, raising the overall height won't bother me, and it'll help counter butt droop when the bed is lightly loaded, which is all it ever is anyway.
If that solution doesn't work, it will definitely be drop shackles.
Good luck on your project.
