1 - 3 of 3 Posts
Hello! Second post on here but i went to shift my truck into 4x4 and the shifter wouldn't move. It wouldn't let me engage it. I bought the truck 2 months ago and just tried it today and its not working. I heard something about vacuume lines being disconnected I put a picture of two one is plugged and one is pretty beat anybody know if its these vacuum lines or something different? Or different lines? Everything helps! Thanks so much! :gr_patrio:rck:
If the shifter itself won't move it's probably rusted up. Either that or there is an issue with the linkage or t case. There is a vac switch on top of the t case that switches the vac for the cad. But the shifter needs to move before you can check that.
The line down by your pinky finger is the vent tube for your front axle. It's suppose to have that white plug looking thing on the end, it's actually the vent.
1 - 3 of 3 Posts
