1 - 16 of 16 Posts
Powered By Coors
Well I did the heater core today... 8 hrs start to finish.. The biggest pain was removing the dash and A/C lines. $95.00 for the core $16.00 for misc hoses/clamps $90.00 for A/C service.... much cheaper than the dealer and I have piece of mind that it was done right..... :rck: :D
4x4, Straight pipe roar!
nice work. You definitley saved yourself a ton of cash. My a/c is shot but I'm afraid to take it in to see whats wrong because I'm afraid they'll say its a $1000 job.
!! Did you do the evaporator core as well?? Another common thing to go wrong, wouldn't want to have to rip that dash apart again!
Powered By Coors
Discussion Starter #4
didn't do the evap... guys who did the A/C service checked it out before the job and said they saw no iminent failure.... hope they are right !!
Kind of like cap and rotor during a plenum install. If it's accessible, do it!
Did you happen to take any pictures?
I might be doing this within a couple months.
Mine is not leaking but I think its clogged.
Powered By Coors
Discussion Starter #7
didn't think about pictures until it was all back together.... sorry
...........I did both, had my mechanic do it however, not enuff time myself to do it...
heater core questions
would you please elaborate on the process , I just bought a Ram 1500 2 days ago and now I realize that the heater core is leaking , now i am debating to take it somewhere or do it myself,, and whats with the heator core anyway i have never had a vehicle that the heater core has gone bad :VHOT: any help would be appreciated thank you
Steve
Powered By Coors
Discussion Starter #10
I've been gone hunting sorry it took so long to get back to you. If you tackle the job yourself, the 1st thing you have to do is have the A/C evacuated. The next thing is to remove the dashboard. That entails removing the insturment cluster, driver side access cover under the steering wheel, lowering the steering colum, removing the stereo, ash tray, cup holder, ABS box cover, disconnect all the wireing harnesses connected to the dash, then removing the bolts across the top of the dash by the windsheild and behind the kick panels under the dash on both sides. The dash will then come out. Next you have to remove the heater-A/C housing. You have to disconnect the A/C lines and the heater hoses to the core. Remove the evap canister and PCM module (do not disconnect the wires, just unscrew from firewall and set aside) then remove the 3-4 nuts holding the housing in place. There are 2-3 nuts inside the cab that need to be removed too. Once the housing is out, remove the 2 screws holding the core in, remove the core and reverse the procedure. Get a factory manual or equivilant before you styart the job. I saved $500+ by doing it myself. GOOD LUCK
heater core
Thanks I guess that I will just GET-ER DONE this weekend , I ordered a core and it should be here Friday , Guess that my weekend is going to be a little shorter :rck:
Hey 96RAM25004x4 bravo!!!! I need to do both of mine (a/c and heat). It scares the sh t outta me to rip the dash out and get it all back together the right way! It also scares me to have someone else do it the wrong way! It's been 2 summers now with no a/c, my heat works fine but smells like someone puked into the fresh air duct, I don't know what the hell it is but my girl don't like driving with me nomore. :dunno:
Does anyone know what that smell could be from, I heard it might have something to do with mold or mildew built up on the heater core itself, I know they sell a cleaning solution similar to lysol that you spray directly into your duct system, was wondering if any of you guys ever used it and how it worked. thanks.
wel its finally done. it took me forever!, because i had to work at 5 the three day it ook me, so right as i got some momentum i would have to stop and go to work. i had to reset my breaklights because i moved the little box thingy from the pedal. the best part is i only have 4 screws left over. im going in the morning to get the system recharged. hope theres no leaks and everything goes fine. everything seems fine tho after hooking everything up.
1 - 16 of 16 Posts
