I have a 92 caravan....3.0 The fan switch will only work on high, and the only position that the heat will blow from in the windshield, no matter what button i press for it to blow from...I thought that maybe it was the control's themselves so i got new ones from the junk yard, i replaced them and its still the same problem, only this time i added a new one to the list, after hooking up the unit, the cable that controls the temperature, popped off, and it appears that i cannot push the switch in the cold direction without the cable resisting and snapping off. I do not seem to understand what has happened with this since this cable is just supposed to rest around this little hook. I would realli like to avoid a mechanic on this one...ANY SUGGESTIONS WILL BE GREATLY APPRECIATED! :huh:
