I went to use my heater in my truck mon. morning and it works fine on max heat (knob turned all the way to the right). But when I try to turn the temp dial to mix in a little colder air with the heat I have no mix of the 2. By the time the temp has changed the knob is almost to the max cold side of the dial and just cold air is coming out?
Is this a common problem for these trucks?
More importantly is it a easy/cheap thing to fix?
Thanks in advance.
Thanks in advance.
