91 voyager 3.3
does the mixture % of coolant and water affect the heat output in the cabin?
reason i ask is the heat output is so so. On a scale of 10, 10 being the max heat output of my other two cars (neon and dakota), the van is about a 7. It's more than luke warm but it's not hot either. i just replaced the thermostat with a 195 deg thermostat, didn't help. current coolant water mixture is good to -20f. no leaks, temp gage stays steady at almost center.
