1 - 2 of 2 Posts
Are there any problems with going with the 80/100 headlight bulbs instead of the 55/65? What about going with the 80s in the foglights over the 55? Has anyone ever had any problems with their wiring harnesses or anything else by going with the higher watt bulbs?
Been HEMIphied
If you use the higher wattage bulbs, the circuit will pull more amps, which could burn out the wiring and possibly cause other damage. There is probably a way to beef up the wiring, but the stock wiring most likely won't handle the amp draw.
1 - 2 of 2 Posts
