Mine's an '03, but the process must be similar. There is an adjustment screw above and inboard of the lamp assembly. Back it out a bit (not a lot, I imagine) to compensate for the raised nose. I had mine leveled recently and haven't changed the headlight settings. They seem OK. No one's "flashed" me yet.
On the '07 there is an adjustment screw behind the rubber flap on the inner side (closer to the radiator) of each light housing, with a t-20 ( I believe) screw. I had to adjust mine as well. It is just an up/down adjustment.
Thanks Nuttsquad03, I saw that but it looked like side-to-side adjustment. I'll give it a try. Hey are you interested in swapping those chrome wheels for some aluminum 20's.
It would be hard to trade. I need the truck for everyday use. If I get my 17's and tires, I will let you know. They would be perfect for powder coating!
