1 - 6 of 6 Posts
was wondering if anybody here has tried the Track Bar retrofit kit by Solid Steel Industries, it has a bolt on mount that will accept a track bar from gen3 trucks to be installed on gen 2 trucks. I have a 96 Cummins powered 4x4 Dually with a severe incurable case of death wobble am wondering if this is the fix I am searching for. :help:
better than you
just get the Thuren trac bar. itll be the last trac bar you ever buy and the best mod you do to your truck.
www.thurenfabrication.com
The Green Machine
I thought about it, before getting one from DT Pro Fab.
With the bracket from Solid Steel, you still have to buy a 3rd Gen track bar and you'll spend about the same amount (or more) than if you get a DT or Thuren bar.
Like Blue said - get a Thuren (or a DT), you won't be disappointed.
I disgaree...:)
The Solid Steel track bar bracket is a good piece of gear. I have used them several of times.
The stock 3rd gen trackbar is a really tough piece. We race them in the stock full truck, and never have failures. I am sure the Thuren replacement is well thought out too.
KP
1 - 6 of 6 Posts
