I have this dang coolant leak that is driving me crazy and I am too cheap to take it in to a mechanic. I have replace all the usual items, pump, all hoses, etc. It has stopped those leaks, not I am leaking again. Looks like I the gasket on the Timing Chain cover died, probably when I did the pump?
Since I removed the water pump, it leaks more, at the seal, which tells me I am on the right track (this round)
Anyway, my delima is removing the Harmonic Balancer. Any tricks on the loosing the bolt? I have soaked with WD40, beat with a hammer and so far no go. I do have a rod that I am using to prevent it from turning. Am I correct in that it is a normal thread and not reversed? Either way I tried both directions.
:help:
:help:
