hay at my dealership they told me i also need to change the fuel filter but is the filter they are talking about the one inside the gas tank cuz that would suck to change or is there another outer one by the frame somewhere like most car, because at checker auto parts theyd ont' even sell it and the computer comes up to tell you that it is not serviceable thanks for the replies
REMOVAL
The fuel pump inlet filter (strainer) is located on the bottom of the fuel pump module (Fig. 32). The fuel pump module is located inside of fuel tank.
If you can do basic mechanical go to Dodge and buy the factory service manual. It will show you where it's located and how to change it. I did the one on my 1996 2500 in about three hours. You don't need a shop but an engine hoist ( to pull the bed) . there's only 6 bolts on the bed and a couple of connecters on the harness. SIMPLE
If the stealership told you your fuel filter needed to be changed, what they really meant was that they need more work and they need you to pay them to change the filter. If the filter needed to be changed, it would say so in the maintenance schedule. Unless of course you're experiencing fuel system problems. Otherwise, tell them to stop trying to screw their customers!
I just ordered the parts for my 30,000 service. It came to 267 from summit. That was all 16 spark plugs, royal purple oil and front and rear diff fluid and oil filter. I will be having a local shop do it. F-the dealer
Hey guys, time has come to replace my half shafts on my 07 Ram 1500 TRX4. It’s got a 6” lift and I run 22R35s are there any brands you recommend avoiding? Any aftermarket brands highly recommended?
Thanks in advance,
Shelby
There is something wrong with my ram 1500 starter.Sometime starts and sometime nothing.
I have checked the starter solenoid ,battery as well as the cable connections,all of they are good.
I assume the problem is the starter itself,since it's has been used for about 7-8 years.
If I asked a...
So i been have a really tough time having my truck get a proper alignment and for it to drive down the road without having to shimmy the steering wheel left and right to keep it riding straight
its a 2006 dodge ram 2500 lifted 6 inches on brand new 37 toyo open county rt tires
has a synergy hd...
hello all
have a 04 2500 2wd 180,000 ml
towing a 7,000 5th wheel
5.7
nv4500
4.11
thinking about building engine
looking for thoughts on ether stroking 5.7 or doing a 6.1 swap local engine builder recommended the stoker for the torque
