Yeah good point, I have done many conversions, the M.P. distributor has about 2 degrees initial, 28 mechanical, 24 vacum, all screwed up! They have to be tweaked to run right on a mildly modded engine, 275+ cam, which needs the opposite, lots of lead, quick mechanical to 2400-3000 then vacum if you wish to utilize it. Thats why I brought up the ignitor petroix conversion, that way he could use the stock curve and vacum, the way the plugs are fired changes only, and of course the dwell stays the same so timng doesnt change as in points type ignitions. Ram Man, I would advise buying it from Chuck Millen at Best Machine or Muscle Motors Eric Budden, that way they could dial it in on a distributor machine,(SUN), and get your curve in the "ballpark" with your engine specs, cam carb compression ect..or else you will have to dissassemble the dizzy to alter the mechanical advance,(slots in the timing plate). It wouldnt be that much more and would really make a difference with a more aggressive timing curve that would be very easy to install.
