1 - 20 of 20 Posts
if i run the factory 4.10s and 44s in 4lo with a 5.2 will i have enuff power and gear for alota fun in the mudd
Blowin n' Goin
UMMMMM, if your like any dodge owner...... NO
I would run some 5.13s at the least. My cousins dodge is running 5.13s with 38s.
Hillbilly Deluxe
I'm running 4.10 with 35s and I wish I had something lower
umm if your a half ton you shouldn't be putting bigger them 38s on it. if you run 44s you will be snapping shafts left and right. i know a kid whos running 5.13 on 42s with d60 front and a gm 14 bolt rear and he still wants lower gears.
Discussion Starter #5
o ya its gettin dana 60s out of an f350 i wanted manual locking hubs and the price was right but ya i was think 5.38s and when the budged alows i was thing about build a little screamer of a stroker motor
Discussion Starter #7
i hope it turns out awsome lol when collage when out the window i have to spend the money on something
6.17s anyone?
Discussion Starter #10
i never even thought of 6.17s but that all depends on the motor when its done can you build a 390 to spin to 8500-9000rpm and try and pull a better part of 500hp 550ftps of tq cause i dont think i wanna go 6.17s with a motor that only spins to likw 6000rpm i need some input and a couple more ideas for everybody on here like im not picky about the body looks shit like that i want some sugegons on some stuff like tires and grears tranny t-case lift the only thing i have my heart set on is 44s my danas and ide love to build a high rpm 390 if it can be done stear me in the right direction guys
Personally if its a bogger, Dana 60 up front, 14 bolt out back, 5.38s with detroits, lots of lift and put in a 440 with a np435 or sm465 with a np205 hanging off the back.
Bulletproof engine/tranny/t-case/axles
i agree what liftedcummins said, d60, gm 14 bolt, 440, sm465, np205:D
work in progress
talk to the guys at hughes engines im working on a 390 now and im looking to turn it at 8-9000 they say no problem
You don't NEED an engine that will turn that high. You need absolute power in the low to mid range. Let the drivetrain/gears take care of the rest.
work in progress
it depends on what you are useing it for mine will see mud runs and a 40000# pulling sled so i will need 8-9000 rpm for my application
Dude you don't need that. Look at diesels. All the power they can get in the 2000-2500 rpm range(their low to mid range).
If you build the engine to make power say between 3500-5000, you'll have plenty for pulling. Set up your gears correctly.
I used to do pulls with a 77 F250. 700hp 460, np435, np205, dana 60 with a 14 bolt out back. It sat on 44" Boggers and had 5.13s in it for gears.
I just put the bitch in 2nd to launch and then upshifted to 3rd. Never had a problem except for stupidly heavy pulls
Discussion Starter #17
so now you guys are steering me into a good torquey big block and all the shit that follows it and would a 727 with a deivorce tcase work? and were back into the 5.38s? and why do you sugest a 14bolt over a dana cause i can get my hands on both no problem but i figered the dana would be better but watever you gauys say is stronger is going in the truck
work in progress
most people in the outlaw class ill be pulling in are running 8-10000 rpm at the line as for the diesels they are running 4-5000 rpm
a gm14 bolt is alot stronger than a rear dana 60 but if you can get a d70 for the rear there really good too
D70 and 14 bolt are about the same in strength, but more options for the 14bolt and cheaper parts.
Now a D80 is one hell of a beast, but its really heavy.
1 - 20 of 20 Posts
