1 - 14 of 14 Posts
i have a 74 dodge 4x4 it has a 3 speed auto. (727 torqflite) i think. it has a divorce transfer case but my tach says im running about 3500 going down the road at 65 i would like to no if this is right or is my tach off. i would like to somehow bring this down for gas milage if i could. my rearend has no cover on it if thats helps its all solid
Swap in a 5 speed. Get a late model bellhousing, tranny, clutch assy., etc. You will need a clutch pedal assy. out of a '93 down truck.
I recall someone else had this idea a while back, don't know who though. lol
The OD would give about 25% RPM reduction depending on the unit. I'd guess about the same for gas milege, plus or minus. It would give you two more gears to use while towing too.
Those RPM's seem high. I've got 33's, a 3.55 gear ratio and 727 (3spd auto) and I think I'm running around 2200 RPM's at around 60 mph. I can't remember for sure since it is my farm truck and I don't take it on the highway much. Your rearend is probably an 8 3/4 with a third member (no cover). The differential is removed from the u-joint side and comes out as an assembly.
idk what the deal is then because my tac says about 3500 but bout 500 idleing and im perdy sure the idle is bout right
500 seems kinda low. I think mine runs around 650rpm or so. I don't have the truck near me as it's in Madison, but there is a sticker on the hood or fender IIRC.
My truck runs pretty high too down the hi-way, but its just 2wd with a 3.73 8 3/4 rear end and stock sized tires.
Aka Force Fed Mopar
I used to have my truck idling at 500. It is a little low though. And yes, you do have the 8 3/4 rear end, if it has no cover.
Sounds like you probably have about a 4.10 gear. I used this calculator http://wahiduddin.net/calc/calc_speed_rpm.htm . I put in 1.2 for the trans ratio (to allow for torque converter slippage).
Since 3rd gear is a 1:1 ratio, the formula to determine RPM is
MPH x gear ratio x 336
RPM = ---------------------
tire diameter
or in your case with 4:10 gears and 30 inch tires at 65 mph
RPM = 65 x 4.10 x 336
30
RPM = 2985
I think idle is usually set around 700 rpm
It didn't take my spaces, here is the formula again
RPM = (MPH x gear ratio x 336)/ tire dia
Aka Force Fed Mopar
Right. But, in an automatic, a 1:1 becomes a 1.1:1 or 1.2:1 ratio, because there is always some slippage in the torque converter.
1 - 14 of 14 Posts
