1 - 13 of 13 Posts
I have an 86 dodge 318 that I can't stop the inside of the tail pipe from being really black. The carb has been rebuilt and all adjustment's are correct as far as I can tell. There is no flooding and the choke is open. Truck starts and runs great.
I am missing something I can't think of. Thanks for any help and idea's.
you prolly never will with the lean burn system the truck has....
acton mike said:
i have an 84 with 318 2 bbl holley - no lean burn; all adjustments apparently correct and the tail pipe is black/sooty
go figure
dosnt it have a computer in side the left fender behind the battery ?
no lean burn system
no electronic controls on the carb
no O2 sensor
while the distributor is electronic, advance is controlled by vacuum and mechanical
electronic engine control, to say the least, is minimal
I may spend some bucks and put an aftermarket carb on it; I have heard good things said about the Edelbrock units. Of course, that may mean changing the intake manifold
If i really wanted to push the boat out, I could go for an after market FI system; TBI would suit me since the beast is my weekend warrior for getting and fetching
However, the Eddy carb and manifold is probably still less costly than an aftermakerket FI system
Do It In A Van
My father-in-law's '85 van is a 318/2bbl. and doesn't have any computer controls. Now on the other hand, my '85 with 225/1bbl. has ESA. Still works fine, so I'm not messing with it.
1 - 13 of 13 Posts
