1 - 2 of 2 Posts
I was just wondering what the easiest way to calculate your gas mileage is. I only get 25 bucks a week for gas and i hardly ever have a full tank so i was just seeing if there was a way to check mpg without running all the gas out of it.
SRT-4
Well... You need to start with a full tank, reset the trip meter, then run it down to where ever 25 bucks will fill it back up completely... 50 bucks doesnt even fill me up, so probably under half a tank... Then when you fill back up check the trip meter and divide that number by however much gas you had to put in to fill it up...
That should give you a pretty good idea of the mileage you get. Unfortuantely 25 bucks doesn't go very far.
I can't really think how you'd be able to do it without starting with a full tank because there no way to know exactly how many gallons you used...
1 - 2 of 2 Posts
