:IDEA: everytime i fill up my magnum rt, i get pissed because the gas cap just hangs there against the paint . so i rigged this up . i'll take some pics and post tomorrow.
items needed
(2 )1/4 screws abou 1" long and nuts
(1) coat hanger (metal)
tools needed
needle nose pliers,screwdriver,dikes
.cut the hanger long about 10"
.there are two "screw holes " in the fuel door the hanger will be going from one to the other with a loop at each end .
.use the needle nose pliers and make a loop at one end of the hanger
.bend the hanger into a slight c shape( to go around the cap when the door is closed) . to the other hole . make loop and cut .
.the hanger with two loops will mount on the inside of the fuel door .
.use the screws to hold the hanger in place.
.now you just push the cap in between the hanger and metal make sure one of the tabs grabs and no more cap against the paint !
items needed
tools needed
