1 - 12 of 12 Posts
Originating Member
In the 70s, truck model designations offered a lot of information about the truck.
Each Model had TWO parts
a letter and a number
Here are the designators:
B = Vans and Wagons
C = Front Section Vehicle
D = Conventional Cab
P = Forward control Chassis
S = School Bus
M = Motor Home
Originating Member
Discussion Starter · #2 ·
ELEMENT 1:
The letter tells us what type of truck you have - for example:
D = 2WD
W = 4WD
B = Vans and Wagons
AD = Two wheel drive sport utility
AW = Four wheel drive sport utility
M = Motorhome
Originating Member
the 2nd part of the model designation is the NUMBER
the Number indicates the GVW range of that model
For example, a D 200 has a higher range GVW than a D 100
Originating Member
Here are the Element number break downs:
B1 = B100
B2 = B200
B3 = B300
C3 - C300
C4 - C400
D1 = D100
D2 = D200
D3 = D300
D4 = D400
D5 = D500
D6 = D600
D7 = D700
D8 = D800
F3 = B300
F4 = MB400
M3 = M300
M4 = M400
M5 = M500
M6 = M600
P3 = P300
S6 = S600
S7 = S700
W1 = W100
W2 - W200
W3 = W300
W4 = W400
W6 = W600
X3 = WM300
Originating Member
Element 2
0 = Forward Control and Motor Home Chassis, Incomplete Chassis, CB300 Caravan, CB400 Caravan, Sport Utility truck type vehicles
1 = Tradesman Van, Conventional Cab and Chassis
2 = Sportsman, Crew Cab and Chassis, CB300 Cab and Chassis (and Step Van in Canada ONLY)
3 = Conventional Cab w/ Utiline, MB3 Low Line
4 = Conventional Cab w/ Sweptline, MB3 Hi Line, Chassis, Cab Tractor
5 = Tradesman Maxi Van, Crew Cab w/ Utiline
6 = Sportsman MAXI Wagon, Crew Cab w/ Sweptline
B = Windshield Cowl, Club Cab
Originating Member
Element 3: GVW Class
numbers are in pounds
A = 6,000 or less
B = 6,001 - 10,000
C = 10,001 - 14,000
D = 14,001 - 16,000
E = 16,001 - 19,500
F = 19,501 - 26,000
G = 26,001 - 33,000
X = Non Certified Export
Originating Member
Element 4: Engine Type
GAS ENGINES:
A - 440-3
B - 225-1
C - 225-2
D - 440-1
E - 318-1
F - 360 1 or 2 barrel
F - 318-3
J - 400-1
K - 360-3
M - 361-4
R - 413-3
X - Special 6
Y - Special 6
DIESEL / CUMMINS ENGINES:
8 NH 230
L SHC 270
Originating Member
Discussion Starter · #8 ·
ELEMENT 5: Year Built
5 = "5" Series or 1975
6 = "6" Series or 1976
7 = "7" Series or 1977
8 = "8" Series or 1978
9 = "9" Series or 1979
Originating Member
Discussion Starter · #9 ·
Element 6: Assembly Plant
J = Windsor Truck Plant, Tecumsech Rd, Canada
K = Windsor (Compact), Ontario, Canada
N = Burt Road (KDX) Michigan
S = Warren Plant #1, Warren, MI
V = Warren Plant #3, Pillette Road Truck, MI
X = Missouri Truck, Missouri
Originating Member
Discussion Starter · #10 ·
ELEMENT 7: Sequential Serial Number
that last series of numbers is the Plant Sequential Serial number
For Example, if the PICKUP Truck VIN reads:
D13BD7S13445
the 13455 is the Plant Sequence number
and Example for a Van would be:
B12AB7V100001
In this example, the break down would be:
B1 = Van or Wagon
2 = Sportsman
A = 6000 lbs or less
B = 225-1 engine
7 = built in 1977
V = Warren Truck #3 plant
and the 1000001 is the sequence number
(and the next one would be 1000002, 1000003, 1000004 etc ...)
Hope this helps
The 'C' designation for the front section van wasn't used until after the low cab forward models were discontinued in the 1975 model year. And when it was used, it was for the commercial use front sections only. The motor home front sections used the 'F' designation starting with the 1976 model year.
Also, the Plymouth Voyager and Plymouth Trail Dusters used letters instead of numbers for their gvw ranges. They were known as PB100, PB200 and PB300 for the vans, PD100 for the two wheel drive Trail Dusters and PW100 for the four wheel drive Trail Dusters.
The element number breakdowns would be BA for the PB100, BB for the PB200, BC for the PB300, EA for the PD100 and AA for the PW100.
Also, your element number breakdown didn't include the two wheel drive Ramchargers(AD100) which was an E1 or the four wheel drive Ramchargers(AW100)which was an A1.
The Lil Red Express had its own special engine which was coded 'S'. All Lil Reds began their VIN's with D13JS.
The 360 4bbl engines had a 'T' engine designation. Chrysler also offered Perkins and Detroit Diesels as well during some of the seventies.
I hope this helps out.
Originating Member
Discussion Starter · #12 ·
thanks
that was some general info, I did make some separate posts with more specific info, like for the LRE
but I appreciate your info
1 - 12 of 12 Posts
