I am fighting an issue with my 2005 ram 1500. My fuel pump relay is not î. It has 9volts returning to the fuel pump relay. Also I have to disconnect the battery so the parking brake doesn't run it down. Thanks for any help
The fuse block under the hood is a known issue to go bad. There are layers of printed circuit boards under the fuses. Years ago these were back ordered, and nearly impossible to get.
Not sure if that is still the case, but be aware that there are several varying styles with different plugs on the bottom. They all look the same on the top. You need the right one for your vin. Not cheap either.
Good luck!
