Ok, I have a bagged 98 Ram with the 5.2. SInce the truck is bagged and has a 5-link, the gas tank is sitting in the bed. I am installing a fuel cell and need to convert it from a returnless sytem to a return system. Has anyone here done this?
If so, .......
1. What year Ram did you pull the fuel rails from? (was it a 5.9 or 5.2)
2. Where did you put the regulator?
3. What did you set the fuel pressure at?
4. Did the setup cause you to get a check engine light (fuel setup or fuel cell)???
5. Did you need to pull anythign other than the fuel rails?
Thanks for the help... :rck:
Yep, job all complete. I used a 49 PSI FPR from a 2000 Jeep Grand Cherokee 4.7L. It is external, a FPR, and has a return. I mounted it right at the fuel cell. Bought a Walbro 255LPH inline pump and mounted it in the bed. No CEL's, just lack the gas guage.
hot2k1ram
how did u tuck the rear tires into the rear fenders?
20X8.5" wheel and a 255 tire.........
got 22's going on the rear this week, will be tucking those too...........
