1 - 6 of 6 Posts
I have an 01 diesel. It has about 140,00 miles. was diving today and when i took off from a stop sign it hesitated really bad and then acted like the engine drated, all i could do was 50 mph, with no power. after about a mile all of the sudden the engine power came back up and drove fine, until that is i stopped and shut off the motor and it all started over again. Checked the codes and cam up with a p0216, which has something to do with a pump timing failure. has anyone had this problem before or have any ideas what it is, any help would be appreciated thanks.
Kent
sounds like the vp is dieing on you. Check your fuel pressure from the lift pump to see if you have any. If you got less than 5psi I'd say you probly burnt it up.
if you got 12psi you should be good to go.
1 - 6 of 6 Posts
