1 - 2 of 2 Posts
My 98 V6 Stratus was running normal, when for a split second the engine stop running then came back to work. This occurred very rare at the beginning, but then the problem became more often until the does not start. My daughter took it to a "mechanic" who changed the crank sensor, the computer, the fuel pump and the gas filters, but nothing. I took the car to my home and checked all fuses and relays, nothing again. Then I sprayed some gas thru the throttle body and the engine run for a few seconds then stop, obviously the injectors are not working. The mechanic who is taking care of it now told me that the problem was the distributor (ignition), so he changed without any result, then he try a lot of thing and finally changed the computer again and nothing occurred. I think that there must be a broken cable or a connector, everything in the car work nice except for the injectors. Any idea?
1 - 2 of 2 Posts
