Buy it and dump it in your tank. The proper way to do it is to have a tool that holds the injector cleaner, and a fitting that threads on to the schrader valve on the fuel rail. The gasoline tends to dilute the injector cleaner. Also a warning, if for some reason you decide to pull the injectors, make sure you have o-rings, don't reause the old ones
