Hi Everyone, I just dropped my 2004 Hemi Limited off at the dealer for it's routine oil change and to check out the hesitation problem when you step on the gas. I got a call from the dealer and was told that the fuel injectors needed to be cleaned to clear up the hesitation, no diagnostic codes showed up when they checked. Does this sound resonable for an engine with only 22,300 miles on it? I mostly use Mobil 87 or 89 octane gas. I used to add a bottle of Gumout fuel injector cleaner in my old 99 D and never had a problem, but haven't on the 04. Now I'm thinking I should start using it again. Any thoughts on using a fuel injector cleaner, brand? Thanks GreyGhost
