yes 97, same way. either drop the tank or remove the bed. the fuel pump,filter,sending unit is all 1 piece. and with a truck 8 + yrs old you might as well replace the whole unit with a new one being you are going through the trouble of removeing the tank. its not required but it only makes sense. drop the tank w/ a floor jack, that way you can lower it just enough to mark the connections unhook them and pull the tank out. its really not that bad of a task. just take your time,and use up as much gas as you can.
