[URL="http://www.goelectronic.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=XN%20700TSV&source=googleps”]Xenarc 700 TSV[/URL] ($335 Shipped) - It is in MINT condition. No dead pixels, touch screen works perfectly. Provided shots of both a pixel test and a touchscreen draw test. Comes with the wall outlet power cable, stand, monitor cable, and a modified power cable that plugs into a molex connector.
Roku M1000/M1001 ($115 Shipped) - It is in mint condition, with packaging, remote, and stand.. I also purchased the under cabinet / wall mount (not shown that cost $35 shipped - it is included).
Philips MMS321 - ($40 Shipped) - These are the speakers I used with the Roku. Loudest set of PC speakers I could find. Sounded great:
# 20W RMS per Speaker
# 40W RMS Total Continuous Power
# 80W RMS Total Peak Power
Sony PSP ($60 Shipped) - Story behind this.. My nephew dropped it and shattered the screen. I ordered a replacement screen ($50) and by the time I got that in and replaced he bought a new one. He said it was flaky with the drive (sometimes the games would play, sometimes not).. I've used it as a media player with no problems. PSP and power cord.
Kicker C10 and Q-Logic QLH-1.0010SE Box ($90 Shipped)
Sub Specs:
Kicker C10 Specs:
Nominal Impedance [Zn], ohm - 4 or 8
Resonance Frequency [fs], Hz - 29.4
Sensitivity [SPLo], dB @ 1W, 1m - 87.3
Effective Piston Area [Sd], in2 (m2) - 57.4 (.037)
Power Handling Watts, Peak (RMS) - 300 (150)
Effective Frequency Range, Hz - 30-500
Effective Excursion [EXmax™], in (mm) - .38 (9.76)
DC Resistance [Re], ohm - 3.70
Voice Coil Inductance , mH - 3.15
Voice Coil Diameter [d], in (mm) - 1 5/8 (40.5)
Voice Coil Length, in (mm) - .99 (25.2)
Mechanical Q-Factor [Qms] - 9.65
Electrical Q-Factor [Qes] - .473
Total Q-Factor [Qts] - .451
Force Factor [BL], Tm - 11.32
Equivalent Volume [Vas], ft3 (L) - 2.27 (64.38)
Moving Mass [Mms], oz (g) - 3.13 (88.8)
Net Displacement, in3 (cc) - 60.0 (982.3)
Outer Frame Diameter, in (cm) - 10 11/16 (27.1)
Hole Cut-Out Diameter, in (cm) - 9 1/4 (23.5)
Mounting Depth, in (cm) - 4 15/16 (12.5)
Magnet Weight, oz (kg) - 33 (.936)
Box Q-Logic QLH10010SE
* width: 16-7/8"
* height: 14-1/4"
* bottom depth: 14"
* top depth: 8"
Sub Specs:
Kicker C10 Specs:
* width: 16-7/8"
* height: 14-1/4"
* bottom depth: 14"
* top depth: 8"
