1 - 7 of 7 Posts
This is for a 2000 Sport 4x4 1500 . I have been told by my mechanic that this is worn out and the cause of the rough ride over washboard / pothole surfaces . Does anyone know of a good place to shop for a new one ? Can I go to a heavier duty one ...say 1 ton ? Is this a difficult repair .....I have a 3 ton jack and the tools ....somewhat of a shadetree mechanic ! Thanks for any suggestions .
You can get one from any 4x4 shop in your area. you can also go from single or duel from companys such as Skyjacker, Superlift, Pro Comp and many others or just go with a stock replacement from your local auto parts store.
D'OH!!
Rocky Mountain Suspensions
They have a good selection to choose from. From replacement cylinders to full kits including brackets. There is no difference between one from a half-ton or a 1 ton replacement cylinder. There might be different issues with the new brackets between the light and heavy duties. What size tires are you running? Up to 35's you'll be all right with a single. 35-up you might want to consider running a dual setup.
1 - 7 of 7 Posts
