1 - 2 of 2 Posts
just replaced wheel hub on my 98 ram 1500, and the stub shaft was very scared up from a broken u-jiont, just replaced the u-jiont and hub and the hub is bad agian after just a month on it could the stub shaft being banged up make the shaft out of ballance and be cousing the hub to go out or do you think it was just a bad hub asembly
If the stub shaft was chewed up before you replaced everything else, I'd be willing to bet it was the stub shaft causing your problems again.
1 - 2 of 2 Posts
