1 - 12 of 12 Posts
im looking to get some 22X10.5 foose rims with 305/45/22 toyo rubber. would these fit without modification to a mildly lowered 4X4? by mild i mean 2/3. discount wheel warehouse says they will fit and theyre advertised as offset RWD wheels.
any help would be awesome. thanks!
i could very easily go 305/40/22
i like lots of sidewall though. it has that muscle car look to it.
would there potentially be problems with 45 vs. 40 ?
all i want is the most sidewall without running into any issues
if you want more side wall go with 20's
why dont you tell how your suspension is dropped ( I think I know) and then I will explain why I suggest 305/40/22 for your
"without running into any problems"
"would these fit without modification to a mildly lowered 4X4? "
did you ever have 275/60/20 on your truck? Did you ever have any rubbing on hard bumps with those IF they were ever equipped??
im gonna drop it with spindles, shackles and remove the overload. it hasnt been lowered yet but im planning ahead so when everything falls into place i dont have problems. and the 275/60/20's are what i have stock.
are the 305/40's the same height as the 275/60's?
antman182 said:
yes, and rancho shocks and i believe you were working on figuring out what to do about the sway bar. :cool:
Anthony from Canada here([email protected])
thanks for the wheel/tire advice. much appreciated
I know who you are now,sorry........the screen name fooled me.I have all of the parts except sway bar sitting here ready for you. dummy me.;)
Discussion Starter · #11 ·
haha, dont worry about it. im sure you get a million emails and pms from people every day.
i cant wait to get everything together. im picturing it in my head and with the drop and rims its gonna be bad ass :)
· You've been Hijacked
ok you say it is a 22x10.5" rim and you are worried about rubbing. What is either the offset or the backspacing for the wheel. I can tell you that I have a 22x10 wheel with pretty much 6" backspacing and i have to run 1/4" spacers on the front to keep the tires from rubbing.
1 - 12 of 12 Posts
