1 - 6 of 6 Posts
So I tried the foglight jumper and it worked. But then my lights were staying on so I took it off and tried it again and now I think I fried my park lamp relay cause my fog lights dont come on. What did I do wrong? Touch the wire to another prong?
Check your fuses
And if it's not your fuses, just swap the relay with another one that you know works (I think the horn uses one). If that fixes your problem, then the relay is probably toast.
Discussion Starter #4
Ok so I guess it helps to put the relay back in the spot you took it out of. Glad I looked at the pic again. But thanks for the advice Rye!!
lol! np
I had the same problem not to long ago and I connected the wire to the wrong prong. Make sure you have it connected right!
1 - 6 of 6 Posts
