1 - 3 of 3 Posts
pmed148
The fog lights just stopped working. The fuses are good and the green indicator on the multifunction switch comes on. The switch seems to check out ok with a MM. The relays in the PCM are ok because I swapped a couple out. I have hooked the lights up to 12v and they both come on. Could something have come loose inside the PCM? I haven't taken it apart yet.
????? :help:
rick_tj said:
Maybe the bulbs burnt out? Loose connectors to the light housings?
He said they came on when hooked up to a 12v. The second statement of the looks connectors may be the best place to start. Mine both went out a week apart, but they are just blown and I have been too lazy to replace them.
1 - 3 of 3 Posts
